4l80 output/ adaptor
gobabygo
Re: 4l80 output/ adaptor
Will not work for syty. I checked in on this and the adapter has a different bolt pattern. And the small shaft will make for a weak 4l80.
Also, if your trans goes out, you need to remove and reinstall this piece.
If you make your TC accept the stock 80e, it's just a tranny swap; no rebuild.
