PPI Typhoon
DIY Madman
Ok, I have the older style 4L80E and have a question about the fittings.
The setup currently has brass fittings in the transmission now. Do I remove those, or do I put new 90-deg adapters on them?
If I'm not going with AN lines, can I just use the RPM adapters? I just get the right size based on what size hose I run, is that correct? (3/8 vs 5/16).
Here is a pic for reference.
Thanks in advance.
Thanks in advance.
