ziembic
I have done a fair amount of searching and reading, and have learned a lot. I have 3 questions.
I am using the JS group buy transfer case shaft.
1) How can you differentiate a 4L80e from other trans?
2) How can you tell 4x4 compared to 2X4?
3) I plan to fully build the one that I buy including billet shafts. I have found one that may be two wheel drive, if it is: is the tail shaft the only difference between 2 and 4 wheel drive trannys?
Thanks in advance for your input.
