I was wondering if you guys had any input into my converter purchase as I am about to pull the trigger. Here goes...
After logging my TC earlier this summer and seeing it was slipping and not stalling where I would like it, I have been scouring the web for options and have settled on Circle D as my next manufacturer.
I have ported RPM vortecs, a 415 cam and a GT35R. On a previous log, the truck started spooling at 2400rpm. When I boosted it, I was holding 25 psi at the line and it was only 80% stalled at 4800 rpm :tdown: I reckon the stall was around 5k rpm. Not good. The truck should have been way, way faster. No sooner than it started to pull but the gears changed and I ran out of RPM. So, I want a known brand converter and I have not read one bad thing about them. I've been browsing for months. Here are my thoughts.
Pro III 258 mm 1B Convetter
I was thinking of getting a 10 1/4" converter from Circle D which stalls at 2500-2700 rpm. It is billet, triple disc and full lockup can be applied at any point. Basically it's a strong SOB! It is a little bit looser than the spool value of the turbo but should be really tight beyond that. I know the truck pulls well when it's tight because when I locked up the TCC at 5mph, it felt like night and day. Soft and spongy vs. a real shove in the back. So this is my top choice.
Pro III 258mm 1C Converter
I was also getting advice from e95 Ty on here seeing as he has a Circle D in his truck (Matt - I hope you're reading this!). His stall was supposed to be 9.5" (245mm) converter and 3200 stall but Matt says he has seen it as high as 3600 or so. Apparently, the 10.25" converter will be a bit tighter than the smaller diameter converter and it has been suggested that I go for a 3000 stall they sell, one stage up from the 1B above. They were worried the 2500 stall above would be too tight.
The thing is, Matt needs the looser stall to spool his enormous turbo whereas I have come to realise my GT35R only really needs about 2600-2800 rpm to get going.
I am very wary of being too high. I don't want to be too loose again and I guess it's a toss up between these two converters. It's a $500 round trip from the UK for my "free" restall so I would like to get this right.
I am strongly leaning on the 1B converter:
But...
I guess I could always spool it with a NOS shot? Right
What do you guys think? I'm almost at the point of saying - screw it, get the 1B and if it is too tight, just leave it for now. Chris has said he'll honour a free restall for 2 years because of my being in the UK. Now THAT is customer service.
So... what do you think?
- It matches the turbo's spool value very well
- Tight is right
- 2500-2700 rpm will probably give a little once the turbo spools placing me bang in the 3k bracket anyway
- The 80e only has a 2.48 1st gear so it is a lot more susceptible to a loose converter and a poor launch.
But...
- I don't want it to be like a 20G/12cm housing with a stock converter and not spool.
