Converting my truck to proper AWD
TurboCharlie
I understand that my truck isn’t a SyTy but I am borrowing a lot of the technology from those trucks for my build. I’m working on an LS swapped 51’ Chevy Five Window truck that’s currently on an S10 chassis. I’m using a lot of SyTy parts to convert my truck into an AWD twin turbo Track Truck. I just ordered a custom limited slip front diff, axles and the output shaft is need to do this from John Frey there at @BullyRacingLLC . Parts should be here in a couple of weeks so that the build can all come together.
QWERTYphoon
Motley Driver Award 2009
I want to do this same build to 1949 Studebaker Champion Convertible. I can't wait for the pictures and the build info; I want to know what I am up against? Looks amazing!
TurboCharlie
The custom built front diff from @BullyRacingLLC just came in and looks like a nice piece of jewelry. It’s got a true limited slip carrier with 3.73 gears and a solid passenger side axle. The custom output shaft for the transfer case and adapter plate should be here in a couple of days. This will enable me to run the 4L80 tranny with the 4472C and be a TRUE AWD truck. Pics and updates coming soon 🙏🏽ED8C0903-5D79-46EF-84FB-B36814660AD0.jpeg
Darius
TurboCharlie and QWERTYphoon,
Well, we are pretty close in our purposes in that my ride also is a bastard clone of grand proportions.
My 1950 Studebaker Champion is sitting on a 1986 S10 4WD - standard cab/long bed - frame where eight (8) of the body to frame bolts lined up perfectly. My engine is old school rather than "New School LS," being a built 1975/76 Cadillac 500 CID bored 0.050 over for a total of 511.5 CID. Being greedy I round it off to 512!
The engine had enough compression to bark when run on the break-in stand, so much so that it will be interesting to see if the E85 fuel, plus water injection will be enough to cover the anticipated 18 pounds of boost from the mid-mounted twin Garrett 3782 turbochargers.
Running gear includes a refreshed front differential, GM 4L85E transmission, backed by a low mileage but rebuilt NVG 149 AWD transfer case from a 2003 Silverado. The rear is a Ford 8.8 IRS unit from a 1995 Thunderbird SC. It has been bolstered with a Torsen limited slip unit. Both front and rear diffs have 3.08 gear ratios as the expected prodigious torque should be more than enough to be interesting.
I wish you both well with your projects!
Darius
dba, bro. d
TurboCharlie
Darius
dba, bro. d
You was able to fit the NV149 under your car? I’d love to see some pics of you have any available. I was contemplating the 149 but didn’t think it would fit.
Darius
Yes, everything fit ultimately, but space underneath was still going to be at a premium. I'll post some pictures in the next day or two.
The big change came when I got tired of trying to accommodate the torsion bars and their large crossmember anchor. Getting that heavy sucker out was a chore. I hammered, squirted with every lubricant and rust dissolver on my shelves, but finally took a 4 inch cutoff wheel to convince whatever was unwilling to move. That done, I was able to use the factory transmission-to- transfer case mount, rather than trying to build something for a divorced transfer case. Luckily there was a like new set of coil over shocks on Ebay at a killer price, so those along with buying a set of appropriate springs made it a done deal! The side benefit was a significant weight sayings!!
Question: is there a limit on picture sizes here?
bro. d
TurboCharlie
I removed the torsion bars when I had the truck stripped to a bare chassis to clean and paint. I got tubular upper/lower a-arms and coilovers. Was you able to run coilovers with the stock a-arms? I didn’t see how they’d fit. Can you PM me and I’ll give you my cell number if that’s ok.
Darius
CHARLIE,
YOU'VE GOT MAIL!
Darius here from the syty.net.
Did you get my private conversation about your project?
