Re: Engine Questions Once Again >.>
I have not found an engine for under $800...
"The first one is a complete stock long block. It has about 84k miles on it. This will be the complete bottom end, heads, valve covers, oil pan. It will not include, intake manifold, exhaust manifolds, turbo, ect. I'm looking to get $800 for that one. That is located in Victor, NY, and could be picked up there.
The second option I have is a built bottom end, but it needs rods and re-assembly. It's a stock 92 Ty block, but it's .030 and has all billet main caps and a billet front cap. This engine only has 1000 miles on it since the original build. The build includes, brand new crank, TRW forged pistons, all the 4 bolt mains, B&M flex plate, fluidamper damper, comp cams 422 cam, comp cams timing set, comp cams lifters, and an edelbrock water pump. With a set of rods and re-assembly, this would be ready to go. This engine does not include heads. $800. This one is located in Alliance, OH."
Everyone states that they don't have a Typhoon engine and I'll have a hard ass time finding one...
Also I want this done quickly so the used engine or a new engine still look like the best option instead or re-assembly or rebuilding one
