Matt
He guys, A little back ground my built 700R4 started slipping this summer and after seeing 2 others in buddies truck pile up i decided i did not want to be building it every year and a half, I picked up a 4L80E today from a 02 silverado, the guy said it has 37000 km on a rebuild for 650,i think this is a pretty decent price, i plan on still opening it up and going through it, i am looking for input or advise for those of you that have done it or are in the process i have searched and come up with this list, please tell me what you think,
So far my list is
2001 or newer 4L80E
80E converter (uncertain on spec)
32 spline transfer case input shaft
rpm 80E crossmember
rpm 80E shifter cable and linkage
rpm trans to transfer case adapter
tci trans controller
wiring Harness
Adjust driveshaft length as required??
Thanks
Matt
So far my list is
2001 or newer 4L80E
rpm 80E crossmember
wiring Harness
Thanks
Matt
