Looking for some advice syclone fuel wiring
Slyclone
Needed some help with a racetronix hotwire. I tried to energize the pump from under the hood and nothing happened. I'm assuming it's a ground I have off? Hoping it is.
I had installed a hotwire and had the tank off/down and forgot to hook a ground up. I tried to turn the key to the on position to listen for pump and it also never energized. .going to check fuses out then the loose eyelet ground.. how come I can't upload the photos I need to here?
Slyclone
Did not get much advise, but I did figure it out. It was a ground wire OFF for the pump/sender. The eyelet style connectors.
For now things are OK. Got power to my pump it kicks on. Can finally proceed to add fuel. I have had the tank empty for quite some time because I was working on the particular area.
