Rexxenexx
Believe it or not this is good news. This might have something to do with my Typhoons performance up top.
Yesterday I was driving in a really bumpy area with train tracks and crappy asphalt when all of a sudden *POP*...*POP*...*POPOPOP*... Sounded like the sub/LOUD from behind, but it was so loud it was hard to tell just I feel only the sub can be so loud. I turned off the headunit, the next bump *POPOPOP*. I pulled over, unscrewed the main fuse to the stereo and pulled it out. Drove around the rest of the day.
Today I removed all the positive cable going to the amps, the subwoofer box, and the amp for the sub. Then put a new smaller gauge wire and a fuse holder to the amp for the rest of the speakers. I just need to buy a 40A fuse tomorrow and test, hopefully it doesn’t sound like a drive-by.
My question is, if you turn off the headunit it should fully turn off the amps because of the remote wire correct? Nothing felt loose except the positive wire kinda looked a little slipped out, but that just may be the jelly like skin. I tugged on everything and it all felt solid. Ground is on the back seatbelt bolt, felt solid. The installer bolted the positive Y splitter to the back of where the amps were mounted. It’s painted so it SHOULDN‘T ground out (?), but there’s nothing between the gold block and that surface. Kinda weird. Considering the above, what do you think could cause a loud *POP*? Might not even be the stereo right? A short somewhere else might feed through to the amps right?
