I'm currently in the process of installing an LSx into my syclone and have a few questions. I have the engine bolted up to a 4l80e with an RPM trans crossmember. I took my angle finder to the tailshaft of the trans and found that it is -6 degrees (pointing downwards). The differential is right at 0 degrees. Do you guys think that the trans pointing down like that is too extreme of an angle or do you all think it is ok to proceed and try to find a wedge for the rear end?
The transmission is already close to hitting the floorpan so there is no room to space it up any or something of that sort. I did a search and really didn't come up with anything so i'm having to ask you guys. Any input in the right direction is greatly appreciated.
