mildtowild
Custom Upholsterer
What performance increase could i expect from my ty if properly tuned with 50% alky injection, 3 bar, apfr stock everything else.
You better add 1 more thing to your list of stuff. That being a new fuel pump as the stock one is at it's limit from the factory.
kinda off subject were did you find out about your alky kit. Im interested in what it is being its mentioned alot on this site. I havent seen one before and I just bought a ty
go here. http://www.code59.org/ search is your friend.I am looking at getting an AEM progressive kit. Not The Best Kit (pump rated for Max 50% Mix), But i can get it local for a decent price.
On a side note, Can chips be programmed to accept a W/B input?
Youre going to regret it. I bought Devils own which WORKS but the controller is pretty much garbage. May as well spend the money the first time. Besides, 50/50 mix will just get rid of knock. You want the power you need to run 100% meth. Just my opinion.
Go with the best get a alky control kit http://www.alkycontrol.com/ :tup:
Not been happy with the devil's own controller myself either, along with the plastic tubing supplied -vs- alkycontrol's braided.
Plastic melts, then you have meth spraying all over inside the engine bay.
