Wow...crazy you mention this! I just cut mine out about six hours ago with my buddies plasma cutter......not sure what I'll put in its place.....if anything!?:lol:Thanks guys. Just trying to see how you dudes cut your rear frame brace to help make the install more safe.
See ya,
i dont believe anyone has removed the stocker and put it back in . I did see pics of an old aftermarket al dustan bar on 1 truck , but I believe they stated their unhappiness with it and ended up buying a new one in RPM's gp chromeoly support thread .
is the engine out of your truck? My Dad and I managed to get it in without removing the rear cross member but the engine was out.
It was tricky but with some patience, a tranny jack and a high lift jack and two ratchet straps we did it.
No point cutting the car apart if you don't need to
good luck
i am able to pull my trans and t-case out separately with the t-bar crossmember unmodified.
Did anyone ever take any pics of this? Or can someone PLEASE take measurements from centerline of how much they did notch? Looking to make this install as seamless as possible with spending $ on coil overs yet.
