BMFB
Not to scale
SO, I've been doing alot of autox in my typhoon, as well as a blazer.
I notice that there is some body roll issues. I am going to focus first on the blazer only because it is a few hundred pounds lighter and should be easy to fix comparied to the ty, and I don't ind aking a mistake on it and F'ing part of it up.
with the ty I dont mind the roll as much, and I decided that it was because the stock posi took care of my traction issues when the truck shifted weight harshley and un-weighted the inside tire. with the blazer and its open diff (something I want to maintain) I end up spinning both inside tires and loosing out in the corners on some grip.
Current upgrades to the suspension are a zq8 sway bar out back with stiff springs, and the stock sway bar up front, both with poly bushings. The front is also sitting on a qa1 coilover setup running 750 lb springs.
I am not 100% sure what is out there. I don't think anything off the shelf is going to be of much use. I a pretty sure I am going to have to build something. If I a wrong and there is somekind of BA bar out there that just makes these trucks so stiff it would make your GF puke let me know (also fee free to turn that into somekind of joke).
