Running now, but...Vibration
crsurf1
Finally got the Sy on the road with new diff and cv joints. There seems to be a bad vibration from 40 to 45 mph. It feels like it's from the rear, but it's hard to pin point. I can see the bed shaking I think. Once you exceed those speeds it clears up and is totally smooth up to ~ 85 mph. I haven't been brave enough to go faster. I'm going to turn the prop shaft one hole and try again. I'm also open to suggestios.
Thanks
Craig
Sy 1542
crsurf1
Rotated front prop shaft one hole....:eek:)
Rotated the shaft one hole and it's much better. I also torqued it to specs which I hadn't done before. The rest of the train such as rear u-joints looked good, so I'm driving her to work tomorrow. She needs new front shocks and a re-balancing on the rear tires which should be done this weekend. There is a slight leak on the new(used) front differential which sucks. all in all I'm pretty pleased.
Craig
Sy1542
