Simple Shift Transmission Controller 4l80e
nr94
swe typhoon
Simple Shift is the latest breakthrough in electronic overdrive transmission control. No laptops or hand-held tuning devices are required to completely control shift points, shift firmness, and torque convertor lockup. All parameters are simply adjusted with easy-to-use dials on the end of the Simple Shift unit. Want a little firmer shift? Dial it up a notch! Do you want it to shift at a lower rpm? Dial it down! Complete control of how and when your transmission shifts is at your fingertips. Simple Shift also comes with complete diagnostic capabilities. Diagnostic codes, current gear, TCC status, and TPS calibration are all communicated via a combination of LED light flashes to help you diagnose exactly what could be wrong with your transmission. The one thing you need to be able to control an electronic overdrive transmission with confidence is simple… Simple Shift
$599.00 http://www.powertraincontrolsolutions.com/simpleshift.php
Billy Graves
Re: Simple Shift Transmission Controller 4l80e
Anyone interested in using a GM TCM from an old 6.5L Diesel for a trans controller? Allot less $$$ and 100 times better software and controls. I have investigated the aftermarket TCM's and would not use one. I still select the GM TCM. And YES it works 100%, has the RIGHT pressures, protection, and correct diagnsotics. If it fails, the TCM you can get one anywhere. Where do you get your aftermarket on fixed? Will AutoZone and others carry them, NO.
TCM, you make the wiring harness, DRAC, Electric speedo or a motor to drive your cable speedo, TPS, Engine speed derived from a 1991 GM Truck V-6 or V-8 ignition module. All parts I used are readliy ava at most parts stores,.
Poconojoe
It doesn't work on Sy / Ty trannies unless you switched out to a 4L60E or a 4L80E
