cloneman315
We started by taking the transfer case apart on the Ty first before taking the trans out etc. The transfer case had normal junk etc. inside. I thought George Blake said that the viscous clutch will be blue when it's bad or do the bind-on-dry-road thing. I dont want to put a ton in this truck, the clutch is not blue and it also does not bind when turning etc.
Here is what I found
Here is the Sy case on top and Ty on the bottom; see the length difference.
Sy case top, Ty case bottom
Sy case 5inches
Ty case 6 3/4 inches
Ty yoke left, Sy yoke right; notice the joint size difference.
Ty transfer case on top, Sy on bottom with part numbers.
Ty case longer overall with yoke
Sy case shorter with yoke
Left Ty and right Sy notice the length difference.I pulled out the Sy yoke so you could see the difference.
new chain in resting position
new chain with a light finger press
All I can say I know you guys are saying the joints are the same size etc,this is only what I found.
Also Sy and Ty have 4 gear planets, not 3 and 4 like some thought.
Quickstop UK said:EDIT: Made this a sticky for reference. Will add to it. Any suggestions for content?
Sy case 5inches
the damn u joints are different from the sy and ty ughh need to change the tailshaft,so it needs to come apart anyways.refund? lol
DaveP said:The difference is the drive shaft yokes. I don't recall that the u-joint itself is different. Swap the yoke, and call it done.
