Bad Ass Black Trucks
What would you do?
I pulled the bad T-case out of my Typhoon. It was hopping a little when turning tight corners in the parking lot. Not a huge deal but was annoying and I wanted to get it fixed.
I bought a "good" T-case that was supposed to be for a Typhoon. When I got them side by side my buddy realized the output shafts were different. DOH! That's a Syclone T-case!
I also have a planetary out of a used low mile truck that is supposed to be good.
How can I tell that the Transfer case I have from a Syclone is good when it is not in a truck? I know they are supposed to slip at about 40 ft. lbs or so. But I can't think of a good way to hold the input and output.
Should I pull the output shaft out of the Syclone Transfer Case and put it in the Typhoon Case or just get a new chain and put the used planetary in the Typhoon Case???
