SY2455 said:According to GM Parts Direct.com the converter is only use on the SY/TY and carry a part # of 08691915. I had heard that the converter was from the Corvette. I have my contact with GM checking on this and will post the results on Thursday.
MHST Guy said::lol: I was just searching for that :tup:
Isn't there some V8 Camaro or similar too?
dgoodhue said:Sorry I am all over the place, but this is what I can rememeber. I am sure their are few little things I missed.
The tranmission include most of the corvette upgrades with a unique valve body, seperator plate, govenor, & output shaft.
The engine includes nodular main caps as well.
Turbo Oil lines & Coolant lines.
The Black GMC letter in availble 92 are unique as are the door handle escutcheons
I think the front shocks are unique as well.
ABS
Crossover is unique as are all air intake connection hoses.
The Coolant overflow flow has another connection for IC. I think the heater to radiator metal section and S- hose are unique. Battery tray is slightly different. The front wiring harness for fog lights, battery cables are also unique.
Black Knight said:I think you might be wrong about a couple things Dave. I will have to double check, but I was working on a '93 or '94 blazer a couple days ago and I swear it had our ABS unit as well as our fog lights. It was a higher end model that had all the options.
Where is the battery tray different?
its not just the syclone has a specific trayShuggsRR said:Man this is a good thread.
So why would the Ty battery tray be different than any other Jimmy's tray?
ShuggsRR said:Ok let me rephrase that question to make you happy. Figured it didnt need an explaination...
So why would the SyTy battery tray be different than any other Sonoma/ Jimmy's tray?
ShuggsRR said:hehe Ok gotcha... That makes more sense
Are the bumper supports the same as S10? the sure do look the same.
dgoodhue said:No, the brackets that attach to the frame are different (both front & rear).
dgoodhue said:I was talking about the ones on the front of the frame. I am not sure about those ones. I image the fender extension support for the cladding are unique as well.
