Tranny HELP !!!!!
jhacking
Hacker
I seem to be having problems getting the truck into park and all of the gears. could someone please help me adjust it please. if you work it a bit in will go in gear but when i go back to park it will not stop the truck from moving,thats no go is it, i'd like to keep my baby
m3cd1
check the shift cable it might be frayed . i had this problm fix it.
it may go at the wrong time :cry:
smeagol
Probably just need to get a new shifter cable. Not that bad a job. I don't think there is an adjustment to it, but I could be wrong. It stretches/weakens and then you have problems like you are describing.
jhacking
Hacker
its a brand new one i had it replaced just because that simple reason it was old now i have these problems and i dont want to take it back where i had it installed . becuase when the truck was there someone broke in is building and tryed to steel the truck.Anyway enough of that story HELP
Hu Ryde
Did you just put a cast pan or a pan that is a differen't thickness on? Possibly a foreign object hit the bracket? WHen I put my TCI pan on it made things so that the gear selector bracket was out of adjustment and did the samething yours is doing. You need to get uder the truck and bend the tap until it goes into park, towards the front. This can go either way but of you ran something over then the tab is probly bent back and just needs to be bent forward some. Tap it with a hammer until it falls into park. HTH
jhacking
Hacker
well i got it to go into park Thanks, had to bend the tab a bit forward.I still am having problems with it going into any of the gears when starting it up. When it does finaly go into gear it stalls the truck.It feels like the converter is locking up,after it gets going and goes through some gears it jumps around a bit , and then after that it works fine no problems until you stop for a while then get back in and it does this silly stuff all over again
B
Blake
Guest
Are you sure they put the correct cable in? Don't mean to ask such a silly question. Was it doing this stuff before the replacement? There is a manual valve inside the valvebody that this cable moves. If that valve isn't in its correct position that could be a problem. There is a spring loaded arm with a roller bearing on the end of it in the valve body that clicks over the teeth on the manual shaft that gives you that "click" detent you feel. This arm could be broken. The only adjustment I'm aware of is the neutral/park safety switch that keeps the truck from being started when in any "drive" gear.
You really shouldn't be driving it if it keeps doing that. What was it doing that made you replace the shift cable in the first place? Maybe there is something else going on.
Blake
jhacking
Hacker
Well is it possible it has the wrong cable i dont know. Its weird becuse like i said it drives and shifts fine after you get going, and no it was not doing this upon till this cable any other suggestions anyone
Hu Ryde
Do you have the PN for the cable you replaced? Did you get it from GM or local auto store? Is it kinked?
