Rexxenexx
Just a drive around the block data log. Wonder if you guys can check it out. See if there's anything weird I should look into.
Basically a long time PNO stock 93 Typhoon. Replaced pump (Aeromotive) and fuel pressure regulator (Sportsmachines) among other small non-critical things. Fuel pressure is set to 42 psi.
The only issue I'm having is it takes two tries at least to start up cold. The starter sounds ok and after I took this Datamaster log I replaced the battery (2013 NAPA), but still took two key turns to get it starting even the day after it got settled with the new battery. Once it starts and idles for a sec, it's smooth. Engages gear back and forth no stalling/hesitation.
