I only have 20psi of fuel pressure on the fuel rail I am going to replace the filter and the fuel pump. This is a stock build what aftermarket pump should I install?
I would also change the sending unit as well. Can’t remember if I had to purchase the lock ring and o-ring that holds the assembly into the tank or not but glad I had, old one was horrible to get out. I went with the 255l Racetronix and Hotwire kit. I intend to modify the Hotwire pump wiring harness buy adding a holding relay and a hidden momentary button switch that requires to be pushed every time you start the vehicle.
