Stridan
Just picked up a set of 19x8 camaro wheels. Going to take care of the hub bore issue but now I am second guessing my tires sizes have picked out. I read somewhere on here that you should NOT go larger then 27" tall. Thinking about a few options for all the way around same size....
____________255/40/19____245/40/19_____255/35/19____245/50/16
..............................Tire 1..................Tire 2..................Tire 3....................OEM
Diameter...............27".....................26.7"....................26"......................25.6"
Width....................10.04"................9.65"..................10.04"...................9.65"
Sidewall................4.02".................3.86"...................3.51"....................4.82"
Circumference......84.9..................83.9.....................81.7.....................80.5
Revs/Mile.............746.5................755.3...................775.3...................786.8
and for a staggered set up if the tire shop wants to fight it on...dont think 285 will fit on 19"x8" wheel
__________255/40/19__OR_245/40/19____285/35/19____245/50/16
...........................FRT......................FRT..................REAR.................OEM
Diameter.............27"......................26.7"..................26.9"..................25.6"
Width...............10.04"....................9.65"..................11.22"................9.65"
Sidewall............4.02".....................3.86"...................3.93".................4.82"
Circumference..84.9......................83.9....................84.3..................80.5
Revs/Mile.........746.5.....................755.3..................751.4.................786.8
Looking at the Pirelli P zero nero tires.... any opinion of Mich, Goodyr, any others? This is not a daily, just a Friday to work and weekend fun. I live in Austin, TX and it is around 100F degrees for 6 months out of the year.... super hot asphalt usually kills performance tires fast with normal driving....
currently rolling OEM and set of ss/zr1(non staggered) 17"x9" with 275/40/17 all the way around.
