OK.....ripped ABS out and thanks to tucker, made it real east to replace the lines. All i have to do is bleed etc.
I will have the factory ABS stuff for sale next week if anyone is interested.
Here is my question
I also installed an MSD 6AL on a custom aluminum bracket that I fabricated where the ABS module was. I kept the plug intact that POWERED the module (red/blk with black connector) to use for future power. I believe there should be a seperate fuse for this in my fuse box? ...anyway... is there any reason that anyone knows of why I shouldnt use this power and ground for my MSD 6AL?. he wire size is about the same size as the supplied MSD wires, and I figure if it will power that big ABS module, it should do the ignition as well....has anybody else done this?
Here is my question
