Alky Tank Location
johnboy89
In the process of installing a Snow Alky kit and was wondering what to use for a tank. I was going to use the washer bottle tank, but the pump I was going to install under the battery tray and instructions state to keep it within 2 feet:rant:.
My other option was to buy another coolant tank and use that and a small cylindrical overflow for the coolant in the grill area.
Anybody have any other thoughts, pix, etc... search didn't give me much???
Thanx:)
Jimmy
Banned
Re: Alky Tank Location
Thanx:)
On the Razor kit,he uses a modified overflow tank for the Alky (maybe you can buy one from him?) and a small coolant overflow that I put near the brake booster.
johnboy89
Found new tanks online for $30, might just do that and modify myself, then do what you did with coolant tank.
http://www.syty.net/forums/showthread.php?t=89121
in this thread I believe you can see how I did mine. My tank is Drivers side front and the pump is just below the tank. If all else fails just come over to my place and check it out.
I am in Woodstock Ct. Its about 15 minutes from RI. ;)
Pix no longer there, do you still have them?
V8 Sonoma GT
Mile High SyTy
took these just for you
V8 Sonoma GT
Mile High SyTy
Yea, I'm brainstorming moving the overflow to that side too, so I can make an Rpm style intake
johnboy89
Not going to work for me oil filter, ABS and stock intake has that corner taken.
I ordered a new tank from ebay for $28, will just use that and move the coolant overflow somewhere else, order a cheap cylindrical one or make one???
V8 Sonoma GT
Mile High SyTy
see how much room you have, then take those measurements to the junk yard, find one the works
