Re: Another cladding repaor thread
The cladding on the truck I have has been painted at some point.
If you have some good pieces I'm sure any shop could color match but being that you can easily remove the cladding from the car I would say it may be more practical to have it all sprayed at once.
Also, I would still use the panel pond to reinforce the tabs on the back side of the cladding even if you have it welded. Stock wasn't strong enough...every little bit of strength helps.
