boost lag/tranny prob?
phoonrt
when the ty gets warmed-up, in first gear to second gear shift the ty sort of dealys and then shifts, is dose it sometimes in other gears--and when i get on it i can hear the turbo spooling but no boost is being used...even my aftermarket gauge is reading around 10psi-but no power fromt he boost--i give it more gas to try and get more boost, but my max is 10psi--then sometimes it dosen't even do it at all--it never dose it when its cold..my tranny slipping?? :-? what the deal with the spooling?? thanks...
SeattleSy#1255
Category 5 Conservative
not sure if this helps but...
I blew my tranny in June, yaya about ayear ago...anyway, I currently only have first and reverse...just enough to pull it out of the garage and put it back in to get the lawn moer out :oops: ----
anyway, I can try to get on it in first and my boost flies up but no power. Now I know my tranny is toast, but i while she was sitting and waiting to get her fixed, I changed the TB and Intake gaskets after cleaning everything out....Since I haven't has the tranny fixed, I don't know which it is. But since boost goes up according to gauge, I attributed it to the tranny...so its my opinion a bad tranny can do that, yet I am not expert--basically a novice on trannys so perhaps someone else can chime in...
Bottom line---my tranny is toast for sure and it does the same thing. could be signs of a tranny heading toward the shitter.
