Re: boost timing help
It's hard to compare the LSX motors to the stock Syty motors. The LB4 heads are by no means a high performance cylinder head and tend to detonate/preignite easily, so timing is usually very mild. The newer Vortec heads are much better in this regards, and seem to like a bit more timing.
Gotta remember, so many calculations go into timing advance that just saying 'I run 15 degrees of timing at 15psi' might not be accurate.
The stock Syty timing table has 16 degrees of timing at 3600RPM and 15psi of boost, and it rises to 21 degrees of timing at 4800RPM and 15psi of boost (just past redline). Stock chip doesn't modify that much, but custom calibrations will tweak the actual timing advance based on coolant temp, incoming air temp, etc. I put some of that in the chips I did a while back, sort of as a safety precaution. Your IC might be really heat soaked, and you might be near overheating; you wouldn't want very aggressive timing advance if you boost it in that situation.
