are you guys that are close to stock -( ie: k&n filter, intercooler pipe, no chip, stock turbo etc)....using the stock boost controller or using a manual boost valve?
my typhoon is all that, but the previous owner added a man boost valve, i posted a question before about a lot of noise at full throttle when the truck was set to 15psi.....in reading the previous posts, learning that the factory wastegate is set for 8-9psi, i think thats what the noise was..overboosting?....what is the cheap/ proper fix?....
...go back to the factory boost valve until I do the fuel/ign/computer mods?.....or change/adjust The wastegate?
slowly learning here!!!!
