Can someone verify these front suspension part numbers?
Ghostman
I have a lowered TY with 17" wheels and the following size tires: 275s in front and 315s in the rear. I have ATR rear bars & Raceproven front swaybars.
Are these heavy duty parts or are there better ones? Are these the correct part numbers because I think some may be outdated?
- Idler Arm: MOOG K6251T
- Right Side Upper Control Arm: MOOG K6327
or
ACDELCO 45J0027
- Right side Upper Control Arm Bushing: MOOG K7104
or
MOOG K6418
- Upper control arm balljoint: K5320
SY2455
70's Veteran
Re: Can someone verify these front suspension part numbers?
or
ACDELCO 45J0027
or
MOOG K6418
My Moog book lists the following
Idler Arm Improved Design: MOOG K6251
Pitman Arm: MOOG K6339
Upper Control Arm Kit: 1 side only MOOG K6283 or (K7104 Note 16)
Note 16 is Problem solver eccentric bushing kit provides additional positive camber adjustment.
Upper Ball Joint: K5320
