Clogged cat, how do I know?
Berra
Well, I have this problem....The truck's running like crap. The only code I get is 43, knock sensor. When floring it, the motor is really bogging. No power what so ever. Could it be a clogged cat? I have tried the "search" function but I can't find what I want....
Regards
Berra
SikVSix
Re: Clogged cat, how do I know?
If you have a temp gun you could take the temp in front and behind the cat. Should be around 100* hotter after the cat if its working.
And from that description it could be the cat, could be other things too Does it idle ok and only feels like its choking off under power or is idle poor also?
Berra
Well, the idle is o.k. but sometimes, when hot, i have 1600-1700nRPM idle so I have to restart the motor to get normal idle (about 700 RPM) I think I have to test the oxygene sensor. I just don't understand why I don't get any codes of whats wrong....just the knock sensor code.
I use the simple "paper clip check".
Replacing the cat is shot in the dark and its most likely going to cause boost control issues if you have the stock turbo.
I would start with the basics Make sure it has the correct plugs, cap, rotor, wires (make sure they are routed not to touch the exhaust manifolds or down-pipe). Replace the vacuum lines.
mattw
IIRC Code 43 is usually tripped when the computer attempts a self-test of the knock sensor and it fails. Basically the computer creates a scenerio that it knows will create knock(too much timing). It then listens for the knock and if it doesn't hear it it will throw code 43 and put you in limp home mode(reduced power, timing, boost).
You should hook up a scan tool and start logging with the engine off.. Then lightly tap on the block with a hammer and see if your knock counts increment. If they don't start troubleshooting your knock sensor, wiring from knock sensor to ecm, etc..
Good luck..
I think code 43 is Can be caused by unplugging the timing wire by the passenger foot well. If someone has been playing with that you might want to verify the timing is set to 0 degrees base.
Since when can changing the cat cause boost control issues? Code 42 is set when tan wire is unplugged.
I'm betting the bogging is timing being pulled because of detonation. Do you have anything to monitor your truck? Datamaster, Tunerpro, Scanmaster?
TY162
Regards
Berra
The bogging could be from a vacuum leak. Verify ALL of the small, very brittle, hard to see, REAL pain in the ass to reach lines, hoses, elbows etc are in place . One SMALL leak can cause that problem..Ask me how I know one:rotf:
The Bronze
It can be a clogged cat. The pre/post temperature check can sometimes identify a cat that isn't "lighting off", but it won't tell you the catalyst is plugged. The best test is to remove the O2 sensor and put a pressure gauge in it's place. If you don't have a gauge, just leave the O2 sensor out and see if it improves. A smart guy would log and review MAP (or use a vacuum gauge), since it will be showing you the decrease in vacuum as you increase engine rpm if indeed there is a restriction.
I am betting on lack of fuel, incorrect timing/detonation or restricted exhaust. Some way to look at the engine data would be really beneficial so we all aren't guessing. ;)
gary sy
i had the same problem just remove the bolts after the turbo and drop the down pipe down as far as u can then start her up and boost brake it. if you now have boost its mostlikely the cat. :2cents:
Berra
Thanks guys!
I replaced the cap, rotor, plugs, ingn. cables, knocksensor and the ignition module and now the truck is running like a raped ape again.
Regards
Berra
Throws
Thanks guys!
Regards
Berra
I got my back into shape (from the PO's neglect), and tracking down a boost-limiting fault was a pain in the ass. BUT, damn... it's so much more fun now.
-P
leusgs
I had the same symptoms. Replacing the Ignition Module was the solution, after hours of cat testing etc.
