mildtowild
Custom Upholsterer
getting a bad clunking when i turn or go over a bump on the drivers side front. does not sound like the clicking of a cv but have been wrong before.
dam, you should of just bought coil over set up for that $$
Actually for $1200 you could buy 2 sets of coilovers for the front and still have about $100 left over.Yea, but that's $1200 and only addressing one possible problem area. That's like saying you're only getting base boost on a stock turbo so you're going to replace it with a GT35r when you could spend the same amount and get a new boost solenoid, vac line kit, silicone couplers, hell probably a new stock turbo, too.
well, went out and got torsion bar mounts, new hubs, upper and lower ball joints, control arm bushings,swaybar bushings, inners, outers, idler arm....... $1200 :rant:
better solve any problems.
Could have gotten a coil over kit almost for that![]()
I could also get a big screen tv for that, as it would have the same effect on the parts I bought. Unless the coil overs replace tie rods, hubs, control arms, pitman arm and idler arm.
I took the shotgun approach to the suspension because the is lot of wear and looseness in the joints, not just for something to do.
Actually a Big screen TV wouldn't reduce your trucks weight by a good 60-80lbs
or replace your shocks, improve cornering, and ride quality by leaps and bounds.
Just want to make sure, everyone knows that a working front coilover setup for these trucks costs roughly $550 from RPM
