The Devils Own Chariot
What the H is this all about? I see the flexplate and converter are not running true. I hear some weird metal clicking noises. I personally installed all the flexplate bolts with lock tight. The engine does not even have 500 miles in it. I did use washers to seat the converter back into the trans better. Is that the issue? I discovered this when I was examining the leaking oil pan gasket in the rear. I wont mention any names on who installed it. You know who you are and thanks for that.
https://www.youtube.com/watch?v=sJSxbSrj8OY&feature=youtu.be
