SchnellGhostTy
Ok so this is the third time I've done this to the Ty, First time I blew the head gaskets, second time I didn't check the clearance on the Eagle Rods and finally this last time the shop F'd up the welding on the oil pan turbo return line bung. Now its finally all back together and in the truck again.
Issues:
***Vacuum only at 9 InHg (Anyone know what I should be running for vaccum?)
***Turbo is spooling 15psi when it was only at 10psi previously... Running straight wastegate spring so not sure whats up with that...
***Truck drives like it has a gigantic boost leak, no power and laggy...
Now what I've done
Pressure tested and found a couple of leaks with some couplers, RPM 58MM Throttle body, two vacuum lines and the only other spot the shop welded on the turbo outlet. So the turbo cold housing is going in for welding again tomorrow and the couple little leaks are being sealed and left to dry over night. With that being said I don't think that these small leaks would cause that big of an issue or am I wrong? I did disconnect the brown wire to set the timing to zero too, but if were off a touch could that be causing it be real laggy and overboost?
Thanks in advance, its been so long in between these builds I might be forgetting something stupid too.
Alex
Issues:
Now what I've done
Alex
