Drivers side window....
4C FED
Absolutum Dominium
It has slid down some for some reason & is open about 3-4".
I have a lot of spiders around my house & I don't want them inside of the truck.
There is no battery in the truck & the complete electrical system under the hood is disconnected.
Where do I need to apply battery power under the hood to get just the window rolled up?
At the Fusible links?
Thanks
SY2932
Administrator
Re: Drivers side window....
Did you disconnect the battery cables too? If not, just connect a pair of jumper cables to a battery with the positive to the red cable and the negative to a good ground. Turn the key to "ON" and roll it up. I just had to do this myself less than two hours ago.
4C FED
Absolutum Dominium
I'll have to go look at it. I'm not sure how I left it last. :lol:
From the battery power goes to the starter, the distribution block on firewall & alt. correct?
bender
If you can ground to frame and apply power to the junction block on the firewall you can get power to roll it up.
4C FED
Absolutum Dominium
No dice. I can get the door locks to operate, but no window motion.
I'll have to bust the schematics out.
For now I just put some painters tape over the opening.
sly dvl
Ya, it's got a Turbo
Strange that it would go down all by itself. Something has come apart. I bet you could just pull it back up and tape it in place.
4C FED
Absolutum Dominium
I don't know what would have broke since it hasn't been used since it worked last time. And it's always worked fine ever since I replaced the motor.
