Sean Krupa
Moderator
Have a Drivetrain howling noise. Replaced the right front wheel bearing due to play and thought the noise was comin from there. Still have the Noise. I removed the Front propshaft and NO more noise. Being that the front diff is still technical turning from the cv axles could it still be the diff? Like a pinion bearing or something? And since the transfercase is still turning the rear 100% I don't know if it would be the transfer case. Any ideas?
All the Fluids were just changed a month ago, along with the Drivers Front Diff axle seal.
The Noise occurs at 20mph and continues to get worse with Speed. The Noise doesn't occur with the truck jacked up with all 4 off the ground coating 20-40mph, maybe only happens with Load, like a bad bearing??
Thanks,
Thanks,
