DYI WB Display
93 TY 2185
For those who use a Wideband o2 for tuning.
I have just finished building the DYI WB and now ready to build a display.
I have always liked analog gauges. But most for this kit are digital or leds.
Is there a good analog gauge to adapt to the wideband?
I found a Tomie and the GReddy gauge but the only come with the o2 sensors and are very expensive. I plan on using the WBO2 for more than just the TY.
Thanks,
Wade Segrest.
smeagol
get a hold of Westach gauges, they can make whatever you want. They did a custom gauge for me for my old wb02 setup.
Maxtor
What specs did you give Westach, Brian? Did they need to have the output voltage vs. A/F value?
The rest of my gauges are already Westach and I would also much rather have the analog gauge instead of the TE5300 LED display that I have now for the WB. It's pretty distracting especially at night.
Also - I am planning on running voltage out to the ECM for datalogging but also want a gauge - can you run both simultaneously without affecting the Vout values (running them in parallel)? [/b]
ed hess
race or get outta the way
maxtor
i just removed a circuit i had tagged onto the ecm ign circuit. changed my drivability drastically. use a diffeerent power source for the switched ignition.
thought it might have been part of my stall problem, and it might be. not sure yet, still looking for other causes. but pulling away from a dead stop was night and day when i removed my circuit from the ecm. standimng still idle was totally different also.
and i have racetronix harness and alternator wire to ecm b fuse socket.
ed
smeagol
[/b]
I talked to a rep there, told them exactly what I wanted, gave them the voltage versus AFR readout, what I wanted on the gauge face. Not exactly cheap, but they can do it.
