You cannot set the boost to below the BASE boost level. The base boost level is what the turbo will produce when you put a boost signal directly to the wastegate actuator. You do this, in effect, when you unplug the wastegate solenoid. To achieve less than the 8-10psi base, you would need to disconnect the wastegate actuator from the wastegate puck lever itself. Truck would be horrible to drive, as the puck would be flapping in the breeze, venting exhaust gases, preventing any spool up of boost.
Kind of a pain to do this. With the Ultimate setup, we set it so that the valet program has low timing, low boost level & boost limiter, a low rev limiter, and I believe we put in richer fueling as well. So it is the next best thing to preventing any boost at all.
