External or stock waste gate???
XIXI
That is the question...???
1. Which is better for performance?
2. Which is safer for the engine?
3. What are the pros and cons of this modification?
Please Advise.
XIXI
12secondSY
Syty Killer :(
Re: External or stock waste gate???
External, only downfall I know of is that its loud. I like it that way though.
Beavis
Still plays with trucks
:stupid: I had a good exhaust guy make me a pipe that goes straight down out of mine and it cut the sound (open air rushing hoopty exhaust) down by 1/2- 2/3. And you hear the wastegate stutter alot more... :tup:
DynaGlide
Ton-Eighty
External gates exhaust gas can be routed to the exhaust of the truck.
1. External
2. External
3. Better boost control > Good ----- Not an amateur mod > Bad
wantingasy
This might sound dumb, but what do you mean by it's loud? Like the loud blow off sound when you let off the gas for instance? :dunno:
XIXI
1. External
2. External
I don't grab number 3 very well, what do you mean by " Not an amateur mod " is this in reguards to the truck or me doing the work.
Please Advise and Elaborate.
XIXI
Ian Turgeon
Cascading Inspiration
an external gate = hole in your exhaust before the cat/muffler. And since it opens under boost, its nice and loud. Sounds like a leaky header.
You can also tell the difference between bleeders and electronic ones just by the sound, bleeders open gradually and stay open at a consistant rate. Electronic ones will flutter on and off more.
An external wastegate has to be welded in. You also probably want to pick the location of where to mount the external wastegate as well before letting an exhuast shop weld it in...
If your running the stock turbo id say stick with the stock setup, it works very well and is clean.
But if you want to upgrae to a bigger turbo and downpipe and such and maybe some headers, than id say the only way to go is external,much better boost control.
wantingasy
After the external wastegate is put in before the cat/muffler, what happens with the internal wastegate that is stock? Sorry if this sounds dumb, I've been thinking about putting an external on.
Ian Turgeon
btw, the wire will work, but welding is better, really all you need is a spot weld on the wastegate arm itself, remove the whole actuator and free up some space.
bezerk
if you shorten the wastegate as mucg as you can and than attach the rod again, you will not have to much problem controlling boost under 18PSI with an external
jamnut
Newbie here with a little question.
If you go with an external gate or even an internal gate with an external boost controller, will you get any computer DTC codes by removing boost control from the stock computer?
I'm a LS1 tuner, don't know anything about these computers, but I do know that I can't just clear DTC's with my HP Tuners on a Sy.
93 TY 2185
You can just leave the boost solenoid electrically connected and the computer is none the wiser. HTH
Ian Turgeon
no need to leave the solenoid connected, mines gone and the harness is tucked away.
ghettosled
SYTY SUPERSTORE
the computer will not throw a code w/ the wire disconnected, and if you tighten the wg rod you will not be able to make full boost. The internal will still leak, so your best bet is to tack weld it as mentioned earlier. The benefit of putting an external on a stock turbo setup is you are able to remove the cat and or free up the exhaust which reduces your EGT's (along ith overall under hood temps) and spools MUCH faster, plus your boost will not creep or spike. the downside is if you upgrade to a larger turbo kit in the future, most of them are already provisioned for the larger wastegates.
Ian Turgeon
yea, what mike said. The external will work with anything, however most aftermarket turbos will have sufficient integral gates that would negate the need for it.
I bit the bullet, the way I look at it theres not much out there that will work better then the external gate. It has residual bennefits besides just being good boost control. I didnt see myself going with much more turbo then a 20g, so this is where I landed...
typhoon92
(XIXI) not steal your thread. But i thought i would ask here since you guys are talking about external wastegates. What boost controls are you running?Manual bleed off valve? Or an electric boost controller?
