Rinda checked out my cable and it was fine. They sent it back along with a new software version and now I can link up. I made a few logs last night and saw a few things I need to ask about:
At half throttle, while accelerating, I have a surge. Boost goes up and down too. The log shows the ECM telling it to do that to the wastegate solenoid. I figured originally that it might be the WG rod adj. but if the ECM it telling the wastegate to go back and fourth can that still be the case? What else would cause it?
Also, the air intake temps were hitting 160+. Ambient was around 70. Does that sound normal? I though it was a bit high.
Integrater is all over the place. BLM is running between 124-128. It's been a while since I played with a Diacom and can't remember how these items should act.
O2's are running 960'ish at WOT. Ok??
No knock retard at all
Any suggestions or anything else I need to pay special attention to? If anyone needs to look at the logs I'll be glad to ship them off when I get home tonight. After I get everything straightened out I'm going with an Ultimate.
