Ordered some new Moroso flexplate bolts to go with my new SFI B&M flexplate. Everything's ok with them, except they came with a washer similar to the ones used on grounds(not much bigger than the bolt head, and all around the outer edges they're cut and turned at an angle like to cut through paint,etc. for a ground) and the stock ones didn't have any washers. Should I use the ones from Moroso with or without the washers?
Jeremy
Jeremy
