I plan on going october 4th. September 28th is the show at E-town. How's your truck running now? Did you fix the intercooler pump yet? Any more codes thrown?
Maybe we can get more of the NASTE crew to go on Oct 4th. Beat up on some Lightings. The air will be cool. Boost will be high and the ET's will be low. Morgan ? Ed? Mike? Mike, you get your truck back yet?
what is going on there Oct 4th? I will definately take a ride down to atco if you guys are going. I only 600 miles on the build but I will bring her out to show my support.
im not sure if im down for this thursday, im trying to keep the miles down on my bald tires. I also cant run cause I still dont have a tranny than can hold a shift. HOPEFULLY but October I will have a transmission and tires, but with the way things work, i doubt it
actually i thought about going tonite but left the helmet at home. besides im still screwin with the f---ing idle thing.
lets se
changed
iac
egr
map
ign module
coil
cap
rotor
plugs wires
temp sensor
vac lines seem tite with tire tube test
fp up down up again
I probably tried other shit but im too pissed writin this to remember.
Hey 50 bucks no make it a hundred if you can find it!
any takers.
dm aint helpin me find it either
didnt test coil pickup yet
only bad till its warmed up.
I would like to get rid of this so i dont have to heat soak the ic warming the piss outta of it so i can race it.
