Help with Bowtie Block part #
firstsy
block # 400965
I looked through GM parts but there was no information on this block number.
Re: Help with Bowtie Block part #
I came across a block like this one on racingjunk.com, I think. It even had specs for the block.
http://speed.racingjunk.com/categor...evy-V6-4.3-Alum-Bowtie-Block-Heads-Crank.html
Block Material A356-T6 Aluminum
Cylinder Deck Height 9.025
Cylinder Bore Range 4.000"
No. Bearing Cap Bolts 4
Cap Bolt Orientation Splayed Steel 2.45"
Bearing Cap Type Steel
Crankshaft Journal Dia. 2.45
Oil Sump Type WET
Crankshaft Seal Type 2PCS
Design Max. Stroke 4.00
Weight (lbs. - bare) 61LBS
Intended Usage
Notes:
450-500 HP
Above Added: Sat July 25, 2009, 8:57 am EST
New Bowtie Block Splayed Caps Wet Sump Part Number 400965
A356-T6 Aluminum
9.025
4.000"
Splayed
Steel
2.45"
wet
2 piece
4.00"
61lbs
Amateur Comp.
450Hp Range Pressed in freeze plugs
firstsy
That is the one I was looking at, but I can't find any information with that block number, was it used ASA racing?
