Re: How high can rev a full-built syty engine?
So i dont wanna bring a ricer-setup in your community.
But high rpm=power, thats the same on every engine! I wanna built a complite setup where everything fits together. I wanna use a GTK-650 turbo. Those turbos needs rpm to get the right flow it needs. Al lot of dragcars rev higher than the syty engine...
I dont wanna go with the flow, i wanna use the potential the engine got. I wanna built my engine where everthing works together and not only put power out from boost.
You seriously need to use the search feature and read.
We clearly do not need rpm to make big power, the basic 4.3 v6 that is in our truck is not a "dragcar" and while some do rev higher, they do not make the power we, or even the Buick 3.8's make on a lower rpm. If you want a drag car, build a motor made for pure racing.
If you can make the same amount of "flow" at 4800 rpm then you can at 8800rpm, whats the point in spinning it that high? The only thing your going to cause is way to much pressure in the cylinders.
If you want a motor that makes great power and not from boost then you own the wrong car. What you are looking for is a N/A motor. Not a forced induction motor. But somehow I doubt you are going to agree, or even see the advice given to you in this thread. So its your money, spend it how you will. Just don't expect to many people to reply to a thread where you aski how to build it again once you blow it up thinking its a 4 banger. :2cents:
