Don W.
Check these DMs.
Look after the 2-3 shift. RPM goes flat. Also look at the RPM trace between first and second. See how it is jagged compared to off the line up to the first to second shift.
https://dl.dropboxusercontent.com/u/86797850/AutoLog_206.uni
Same with these only the truck continues to accelerate, sort-of .
https://dl.dropboxusercontent.com/u/86797850/AutoLog_208.uni
https://dl.dropboxusercontent.com/u/86797850/AutoLog_209.uni
https://dl.dropboxusercontent.com/u/86797850/AutoLog_210.uni
I'm fairly certain this is ign related but where? Except for the flat line in DM 06 I can feel it begin to miss a bit in the traps (highest load on the motor hence highest load on the ign.) So the question is.. module (or the dist itself), coil, wires are fairly new, plugs at .028 (haven't pulled them yet.)
I'm leaning toward module first then maybe coil, followed by dist itself, then wires. Mostly because I already have the other parts.
Thoughts, ideas, much appreciated.
