Re: Injector duty cycle and afr
The stock ECM doesn't adjust to target AFR under WOT. Like Servando said, in Datamaster with the stock setup you are looking at "target" AFR not "actual" AFR. Some aftermarket engine management systems such as FAST can provide O2 correction via input from a wideband O2 sensor in closed loop mode.
If you get a WBO2 and are able to read actual AFR, keep in mind 14.7 is stoichemetric (sp?), but under boost at WOT a turbocharged engine needs richer conditions to avoid detonation and make power. Typical AFR's under boost should be anywhere from 11/1 to low 12/1 ratios. I would strongly suggest that you do not back fuel pressure off to lean it out without knowing what you are doing.
