Ruddell
I have a strange problem.
The Check engine light does not come on with the key up. It will come on for a split second at times, if I turn the key on and off really fast it will stay on but as soon as I stop it leaves. I redid the grounds for the ECM. Checked the plugs and chip on the ECM. At one time when I was turning the key back and fourth the engine light decided to stay on, and it started. I was stumped as to why, but everything worked consistently over and over until it didn't. While it was running I tapped on the ecm and played with all the plugs and wires and it didn't skip a beat. It will not start if the light dosnt come on and stay on with the key up like every truck supposed to do. I hope this makes sence, I'm lost. Does anyone happen to have any ideas about this from your experience?
