IROC Wheels on my Typhoon-
Philip
I have a set of the ugliest Corvette rims I can imagine that came on my Ty, and want to change to some black IROCS, can someone tell me the fit I need? Is it back on front and vice versa, or will rears fit all the way around? I have a front and a rear now, so can shop for anything.
Thanks!
asmo
Sy #2918
Re: IROC Wheels on my Typhoon-
Iroc's have the wrong offsets for us, they only fit 2wd s10's
RealFastV6
@jb_and_his_coffee
I believe the common Iroc 5 spokes are 0 offset front and 13mm offset rear.
If you used 4 rears (13mm offset) all the way around, your rears would be correct (ours are the same, 16x8, 13mm offset) but you'd need 1" (1.1" really) spacers in the front to get it out to the correct place.
asmo
Sy #2918
You're right on the rear but syty stock front is 40 offset.
The rear 13 offset iroc wheels would stick out almost an inch up front
The 0 offset will stick out almost 2 inches.
The spacers would make it a lower offset so ya, no workie.
The 95+ camaro wheels fit ok and are available cheap everywhere.
Philip
your right on the rear. but syty stock front is 40 offset.
the rear 13 offset wheels iroc would stick out almost an inch up front
the 0 offset will stick out almost 2 inches.
The spacers would make it a lower offset so ya no workie.
Thanks, are the 1995+ Camaro wheels the same front and back and if so, how can I configure them to work?
Really appreciate the help!
RealFastV6
@jb_and_his_coffee
Yeah you're right, I did the math right but I went the wrong way.
They'll stick OUT 1.1 inches.
Yeah, ain't fixin that with spacers.
Gnocide
turbo game burt reynolds
2000 z28/trans am wheels work 16inch
you need a spacer for the rear only
photos of the t/a wheels are in my signature build thread near the end
Ruddell
I don't know about anyone else but I think it's hard to beat polished stocks on a Wht/Wht...
It's meant to be...
Gnocide
It's meant to be...
polished or chrome stocks are without a doubt the best choice
that looks great
