Lynn D. Brown said:but I think it would be low - something like 5-10 Ft-Lbs.
dgoodhue said:Its gotta be false, did you torque down the sensor with a torque wrench?
decodave said:dgoodhue said:Its gotta be false, did you torque down the sensor with a torque wrench?
False, how?
decodave said:I didn't torque it, just average tightness. I would think for it to loose enough for a "soft?" install it would fall out.
I'm still thinking loose pistons.
Hey, wait....I'm Dave & my sy is 2662
dgoodhue said:decodave said:dgoodhue said:Its gotta be false, did you torque down the sensor with a torque wrench?
False, how?
A good way to tell if you getting flase knock is by reving it neutral, you should get any knock real knock counts from that.
????. Like I said earler, between 2k & 4 something k It shows continuous knock in nuet.
It really needs to be torqued, average tightness is probably too much. I relocated my Knock sensor yesterday and torque down a new Knock sensor, I was suprised how little 14ft-lbs is. I think the rubber coating on the bottom of the sensor play a little into that.
It if make you feel any better, your sy's brother #2661 is having knock retard problems as well, but I know his knock counts are real. My truck first two owner were from San Diego, CA.
False, how?
