Hey Guy's.
OK, I did some searching here and on the list archives. This is what I have come up with so far.
My transfer case is leaking from between the the 2 halfs. This seems like it might be a common problem. From the list archive, it seems the concensus is to use RTV to seal it up.
What color RTV should I use?
Also, do I need to drop the transfer case to do this?
If I do have to drop the case, How can I tell if there is any damage within the case? (the case does still have fluid)
Anything else I should replace if I have it down?
Last question, is this something an amatuer like myself could do, or should I take it to a mechanic? How expensive might a mechanic be for this?? 1000 bucks??
Thanks,
Chris Zaccagnini
Thanks,
Chris Zaccagnini
