If you've got an aftermarket 2-4 servo installed, make sure there is a lot of clearance between its cover and the trans tunnel. When the driveline torques over, any interference can mash the servo rod into the 2-4 band inside the trans, can dent the dimple in the band, resulting in huge clearances. Mine did this - 2nd was fine, when came time for 4th, felt like it was going into neutral; revs go up, vehicle slows down. MIGged a blob on the servo rod where it contacts the band, got back the 1/16" or so clearance (it was 3/8"+) on the cover. Accessed the servo via a hole cut in the tunnel on the passenger's side, replaced spaced out 1/2" for clearance. Problem solved.
BTW, also easy to access the Sy fuel tank fittings via a hole in the bed if you don't mind doing it. Tank R&R is pretty easy then.
FWIW, YMMV, etc - Barry
